Startseite » Forenübersicht » Kamera und Technik » Sony A-Mount Kameras » Neue Sony Alpha 200
Thema geschlossen
Alt 06.01.2008, 19:20   #1
Saludo
Neue Sony Alpha 200
Hänge ich böse hinterher, oder hab Ihr den Link zur neuen Alpha 200 hier noch nicht veröffentlicht?
http://www.newsdesk.se/pressroom/son...valitet-188410
Hier gesehen
http://forums.dpreview.com/forums/re...ssage=26317581
Michael
Jetzt funzt der Link
Geändert von Saludo (06.01.2008 um 19:26 Uhr)
Saludo ist offline
Alt 06.01.2008, 19:33   #2
DonFredo
Hallo Gemeinde,
wenn es denn stimmen sollte, hier die Daten:
200 Key Features
Camera type Digital SLR with built-in flash and interchangeable lenses
Lens mount Compatible with Sony  lenses and Konica Minolta/Minolta MAXXUM/DYNAX lenses
Image sensor APS-C size CCD with anti-dust system
Sensor resolution 10.2 effective megapixels
Image processor Sony BIONZ engine
Image stabilisation Super SteadyShot with approx. 2.5 – 3.5 EV decrease in shutter speed (actual stabilisation depends on shooting conditions and lens)
Noise reduction Long exp. & High ISO NR at ISO1600 / 3200
Creative Styles Preset modes: Standard, Vivid, Portrait, Landscape, Night View, Sunset, B/W, Adobe RGB. Adjustable parameters: Contrast, Saturation, Sharpness
D-Range Optimiser operating modes: Off, Standard, Advanced
Scene Selection modes Portrait, Landscape, Macro, Sports, Sunset, Night Portrait / Night View
Viewfinder Field of view: 95% / Magnification: 0.83x
AF system TTL phase detection, centre-cross 9-point
Sensitivity ISO100 - 3200 equivalent(Recommended Exposure Index)
Light metering 40-segment honeycomb with multi-segment, spot and centre weighted modes
Flash modes Auto, Fill-in, Wireless, Rear, High Speed Synchro and Slow Synchro (Wireless and High Speed Synchro modes require optional accessory flash HVL-F56AM or HVL-F36AM)
Built-in flash system Auto popup (GN 12) with manual popup button
Shutter speed range 1/4000 sec. - 30 sec., bulb (Flash sync speed 1/160 sec.)
Continuous shooting rate Up to approx. 3 fps
Max no. of frames JPEG Fine/Std: unlimited (until memory card is full), RAW+JPEG: 3, RAW: 6
recordable (continuous)
Monitor screen Transparent TFT / 2.7-inch Clear Photo LCD (230k dots) with AR coating
Histogram display Brightness, RGB
Function menu Camera Function Display with direct control of Flash Mode, AF Mode, WB, Metering Mode, AF Area, DRO
Battery type NP-FM500H with InfoLITHIUM % power remaining display on screen
Battery life Approx. 750 shots (CIPA measurement)
Vertical control grip VG-B30AM (optional) accepts up to 2x NP-FM500H batteries
Recording media CompactFlash card: Type I, Type II (Microdrive)
Memory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO-HG Duo with optional adaptor.
Dimensions (WxHxD) Approx. 130.8 x 98.5 x 71.3 mm (excl. protrusions)
Weight Approx. 532 g (w/o batteries or memory card)
Manfred
DonFredo ist offline
Alt 06.01.2008, 19:35   #3
TorstenG
Glaskugel-Thread im Café!
Ich verschieb jetzt mal nicht, weil sonst gleich der nächste einen neuen Beitrag aufmacht!
Es ist sehr gut möglich das das die neue Kamera ist die Sony vorstellen wird!
TorstenG ist offline
Thema geschlossen
Alle Zeitangaben in WEZ +2. Es ist jetzt 02:30 Uhr.
