Produktfeuerwerk bei Canon 1Ds mark III
Nachdem bei Amazon.com jetzt die gelistete 40d aufgetaucht ist, siehe auch den anderen Threat dazu,
sind dort jetzt auch die Daten der 1Ds Nachfolgers aufgetaucht: 1dsMarkIII Technical Details 21.1-megapixel full-frame CMOS sensor Large 3.0-inch LCD display with Live View and seven brightness settings 5 fps at shutter speeds 1/500 second or faster (for bursts of up to 45 Large/Fine JPEGs or 15 RAW images) sRAW mode; 35-zone metering system; 45-point AF; integrated Self-Cleaning Sensor Unit Powered by LP-E4 lithium-ion battery pack; stores images on CF, SD, or some SDHC memory cards › See more technical details -------------------------------------------------------------------------------- Product Details Shipping Weight: 6 pounds (View shipping rates and policies) Shipping: Currently, item can be shipped only within the U.S. ASIN: B000V5LX00 Item model number: 1Ds Mark III Date first available at Amazon.com: August 19, 2007 Would you like to update product info or give feedback on images? (We'll ask you to sign in so we can get back to you) -------------------------------------------------------------------------------- Product Description From the Manufacturer The new 21.1-megapixel, full-frame Canon EOS-1Ds Mark III digital SLR camera brings the power of Canon's professional imaging excellence and innovation into sharper focus than ever before. While Canon's EOS-1D series has dominated the 35mm-based professional Digital SLR market for the past six years, the new EOS-1Ds Mark III digital SLR takes Canon's pro-digital prowess into and the realm of high-fashion and commercial photo studios where bulkier, medium-format cameras previously reigned. The Canon EOS-1Ds Mark III's compact, lighter-weight magnesium alloy body is rugged and versatile enough to take out of the studio and into the field. The camera's fast, five-frame-per-second (fps) shooting rate for bursts of up to 56 Large/Fine (21-megapixel) JPEGS or 12 RAW images is unmatched in its class, making it the ideal instrument for capturing the fluid motion and free-flowing lines of location-based fashion photography as well as a wide range of other professional photographic applications. Revolutionary Resolution Developed and manufactured by Canon specifically for the EOS-1Ds Mark III digital SLR, the camera's new full-size 36 x 24-millimeter CMOS image sensor offers the highest resolution in its class and is comprised of approximately 21.1 million effective pixels (5632 x 3750) set at a pitch of 6.4 microns. The user can select any one of six recording formats ranging from 21.0 megapixels in Large JPEG or RAW format, 16.6 or 11.0 megapixels in the two medium JPEG sizes, or 5.2 megapixels in the small JPEG or "sRAW" formats. In any JPEG format, the user can set one of ten compression rates for each image size. In sRAW mode, the number of pixels is reduced to one-fourth that of a standard RAW image and the file size is cut in half, while retaining all of the flexibility and creative possibilities associated with full-size, traditional RAW images. Dual "DIGIC III" Image Processors Fulfilling the ultra-low noise, ultra-high image quality promise of the EOS-1Ds Mark III Digital SLR camera requires handling the enormous signal processing requirements of the camera's 21-megapixel resolution and top continuous shooting speed of five fps. To accomplish this, Canon has incorporated two identical DIGIC III imaging engines into the camera for parallel (and hence, faster) signal processing. The CMOS sensor reads out to the dual "DIGIC III" processors simultaneously in eight channels. DIGIC III is the next generation of Canon's proprietary image processing engine. This technology ensures the fine details and natural colors of images are optimally recorded and, as an added bonus, is responsible for the EOS-1Ds Mark III SLR's high-speed performance, faster signal processing, and more efficient energy consumption. Adding to the improved virtuosity of the images captured by the EOS-1Ds Mark III Digital SLR camera is the camera's 14-bit Analog-to-Digital (A/D) conversion process. Able to recognize 16,384 colors per channel (four times the number of colors recognized by the EOS-1Ds Mark II Digital SLR camera's 12-bit conversion capability), this line-leading model is able to produce images with finer and more accurate gradations of tones and colors. Additionally, given the significantly larger image file sizes created by the EOS-1Ds Mark III Digital SLR camera, Canon has provided compatibility with the new Ultra Direct Memory Access (UDMA) compact flash memory card specification, which enables ultra-high-speed data transfer to the card. Utilizing a UDMA compliant card doubles the data transfer speed compared to a conventional memory card, putting the new EOS-1Ds Mark III on par with the 10.1-megapixel EOS-1D Mark III camera, even though the pixel count of this new model is more than twice as large. Advanced Autofocus Technology The EOS-1Ds Mark III autofocus system--first introduced earlier in 2007 on the EOS-1D Mark III Digital SLR--has 45 AF points including 19 high-precision cross-type points and 26 Assist AF points. This new array allows the 19 cross-type points to be divided into groups of nine inner and nine outer focusing points plus a center point, which makes picking an individual focusing point much faster and easier than going through all 45. During manual AF point selection, the AF point area is expandable in two stages via Custom Function control. At the request of sports and wildlife photographers, a new micro-adjustment feature allows for very fine changes in the AF point of focus for each lens type in use, along with the addition of adjustable focus-tracking sensitivity as another sophisticated new AF feature. Other new components in the AF system include the reconfigured concave submirror and the secondary image formation lens, both products of Canon's vast expertise in optical engineering. Finally, the low-light sensitivity of the new AF sensor has been doubled to EV-1 for superior performance compared with earlier EOS Digital SLRs. Live View One of the dynamic innovations incorporated into new EOS Digital SLRs--and optimized for professional shooters on the EOS-1Ds Mark III digital SLR--is Canon's Live View shooting mode, which provides photographers with an expanded and exceedingly convenient set of shooting options beyond the conventional SLR through-the-lens viewing. Framing and shooting subjects using the camera's LCD screen affords the shooter the same 100 percent field of view provided by the optical viewfinder--this is a full-frame Digital SLR after all--but Live View has the added advantage of allowing the image to be more easily composed on the camera's bright and brilliant 230,000-pixel, three-inch LED screen. Additionally, the LCD-viewed image can be magnified by five or ten times in order to ensure that the shot is optimally focused. Live View is at its best during tripod shooting, particularly for close-up photography where precise focusing is imperative. As a side benefit, the Live View shooting mode helps to reduce vibration by lifting the reflex mirror out of the optical path well in advance of the exposure, improving image quality at slow shutter speeds. Additionally, as the release time lag is miniscule, even instantaneous movements like a bird taking flight can be readily captured. The shutter charge sound can be delayed and made quieter than normal in Live View mode to avoid spooking wildlife or disturbing people nearby with unwanted camera sounds. If a user is going to be several feet away from the camera, such as in some studio settings, the EOS-1Ds Mark III can be connected by cable to a computer via its USB 2.0 High-Speed interface. The camera can also be operated remotely at distances up to 492 feet with the assistance of the optional Wireless File Transmitter WFT-E2A, which allows users to view images directly off the camera's sensor in virtually real time, with the ability to adjust many camera settings quickly and easily. Viewing Display Easy to read, even in outdoor conditions such as bright sunlight, the EOS-1Ds Mark III Digital SLR camera features a three-inch, 230,000-pixel wide-angle LCD display screen. The TFT color liquid-crystal monitor features seven user-settable brightness levels and a wide, 140-degree viewing angle, both horizontally and vertically. An added advantage of the large, three-inch display size is the ability to utilize a larger font size for text, making it easier to read setting and menu options on the screen. Canon extends its "ease-of-reading" policy to the EOS-1Ds Mark III's viewfinder as well. Bright and clear with zero distortion, a 100 percent picture coverage, and a magnification factor of .75x, it is the finest viewfinder ever placed in an EOS camera. EOS Integrated Cleaning System Another first for a professional digital SLR of this caliber is Canon's complete dust management solution, called the EOS Integrated Cleaning System. The new CMOS image sensor is designed with a lightweight infrared absorption glass cover that vibrates for 3.5 seconds when the camera is turned on or off. This brief delay can be cancelled immediately upon start-up by pressing the shutter button half way. Dust that has been shaken or blown loose of the sensor is trapped by adhesive surfaces surrounding the sensor unit housing, preventing the problematic particles from reattaching themselves to the filter when the camera moves. Like its sibling, the EOS-1D Mark III, the shutter of the EOS-1Ds Mark III Digital SLR camera carries a durability rating of 300,000 cycles and, though it generates less dust, still charges itself three times during the manual cleaning process so that dust is shaken off the shutter curtains as well. This cleaning system uses very little battery power and can be turned off in the custom function menu. The second part of the dust management system is a software solution that maps the location of any spots that may remain on the sensor. The mapped information is saved as Dust Delete Data and attached to the image file. Subsequently, the offending dust information is subtracted from the final image during post processing, using the supplied Digital Photo Professional software. Rock Solid Reliability The entire body of the EOS-1Ds Mark III, including its internal chassis and mirror box, is made of an advanced magnesium alloy for exceptional strength and rigidity. Comprehensive weatherproofing at 76 locations on the camera body ensures superior reliability, even when shooting in harsh environments. Together with the 300,000-cycle shutter durability rating, these features result in a camera that, even though it is six ounces lighter than the EOS-1Ds Mark II, can truly withstand even the most severe shooting conditions. Improved Software Among the most valuable features of the EOS-1Ds Mark III Digital SLR is its compatibility with Canon's new Picture Style Editor 1.0 software. With PSE, photographers can personalize the look of their photographs by inputting their own preferred image processing parameters, including custom tone curves. The EOS-1Ds Mark III Digital SLR also ships with the latest versions of Canon's powerful software applications, including Digital Photo Professional 3.2 and EOS Utility 2.2, which support the camera's Remote Live View and Dust Delete Data functions, as well as incorporating a broad range of additional improvements designed to improve image quality and speed up workflow. Particularly noteworthy in DPP 3.2 is a new Lens Aberration Correction Function that corrects various image defects such as chromatic aberration, color blur, vignetting, and distortion. Initially, the Lens Aberration Correction Function will support images captured by the EOS-1Ds Mark III and 11 other EOS Digital SLRs using any of 29 individual EF and EF-S lenses. Also included are ZoomBrowser EX 6.0 and ImageBrowser 6.0 for easy browsing, viewing, printing, and archiving with compatible computer operating systems, including Microsoft Windows Vista and Windows XP, as well as Mac OS X. Canon EF 14mm f2.8L II USM Lens Designed primarily for discerning landscape and architectural photographers, the Canon EF14mm f2.8L II USM lens is ideally suited to the EOS-1Ds Mark III's full-frame capability. Measuring 3.7 inches in length and weighing in at under 23 ounces, this ultra-wide angle L-series prime lens is well corrected for rectilinear distortion, provides a 114-degree diagonal angle of view, and delivers high-speed autofocus with higher image quality overall including superior peripheral image quality, compared to its predecessor, the stalwart EF 14mm f2.8L USM lens. While its large diameter, high-precision aspherical and UD elements, optimized lens element positioning, and flare and ghost-reducing lens coating ensure that this lens delivers the top optical performance in its professional class, Canon has added other features photographers have been asking for--improved dust and water resistance incorporated around the mount, switch panel and focusing ring, and a round aperture that creates a nice background blur and makes it easier to recognize an out-of-focus scene in less than brightly lit conditions. Furthermore, Canon has created a new lens cap specifically for the EF 14mm f2.8L II USM that is held to the lens by a stopper. Black Jetzt fehlt nur noch, das die auch noch die 5d Mark II listen....
Die Wahrheit ist ein Chor aus Wind Blacks Home (ok, im Aufbau, ich arbeite noch dran) |
hättest da doch wenisgtens...übersetzen können???
wichtiger aber...der Preis??? Mfg gpo |
@gpo: Lt. Link im obigen Post bei amazon 7999,99$.
http://babelfish.altavista.digital.com/babelfish/tr Hth, Jan Geändert von jan.winkel (19.08.2007 um 12:55 Uhr) |
gas kling jetzt wohl in Canonlager ketzerisch aber bei so viel Geld investiere ich lieber in eine Rollei oder Hasselblad Da finde ich den Preis gerechtfertigt und bin mit dem Gesamtsystem wesentlich flexiebler und die Gesamtqulität ist stimmig. Gruß WoBa |
#5 | |
Nur Eine Hasselblad ist zur Monsunzeit im regenwald oder beim Sport leicht bis Mittelschwer im Nachteil. Die 1Ds ist da universeller. Gruß,- Black
Ach Black,
musste das jetzt sein? Musstest Du wieder Salz in die offene Sony-Wunde streuen? Aber ganz im Ernst. Ein hammerstarkes Stück Technik. So zum dahinschmelzen. Aber der Preis... Bin ja einmal gespannt auf die ersten "Field-Tests". Halte uns auf dem Laufenden. See ya, Maic.
Sensorart | 1001 Cars - Cars, Bikes & Rockabilly | Mein Profil in der FC | FreiesFotoForum |
Höchst beeindruckend. Da hat sich der Marktführer was einfallen lassen, Respekt.
Jetzt stellt sich nur noch die Frage wann die passenden Linsen dazu auf den Markt kommen. Denn selbst die besten Canon-Gläser haben ja schon bei 16MP Auflösungsprobleme, bzw. sind an ihrer Auflösungsgrenze.
Prost!!! WB-Joe Nächster Stammtisch in München: Dienstag, 03.11.2026 So kannst du das Sonyuserforum und unsere Arbeit unterstützen |
#8 | |
Zooms wirst vergessen können, sind nur noch ganz ganz wenige zooms, die an der alten 1DsMKII mit ihren 16 Mpix bestehen konnten. Die neue mit Ihren 21Mpix wird wohl nur noch primes vorne drauf mögen. Canon Primes gehen aber noch deutlich weiter als die 16 Mpix, von daher sehe ich da nicht so die Problematik. Vor allem, da die Käuferschicht der 1Ds zumeist eh ein Regal voller rotrandiger Prime-Gläschen rumstehen hat. Ich sehe eher Probleme in Sonys Objektiv Portfolio, wenn die mit 12 oder Mehr Mpix auf Crop rauskommen und noch wesentlich mehr, wenn die eine digitale Fullframe >16 Mpix bringen sollten. Auch Minolta G-zooms wird in diesem Bereich die Auflösung ausgehen, von uralt Standartzooms rede ich da besser gar nicht. Bei Nikon siehts übrigens etwa gleich aus, Nikon Optiken lassen sich aufs EOS Bajonett adaptieren, und so wurden schon so manche Nikkore am digitalen Fullframe gecheckt. Auch da liegt die Grenze in Höhe der EOS Optiken, und da wird Minolta wohl eher nicht die Ausnahme sein. WIe man Optiken berechnet und baut wissen alle dreie. Leider läßt sich wegen dem Auflagemaß das MAF nicht an ein EOS bajonett Adaptieren, sonnst hätte ich interessehabler schon mal so manche Linse an meiner 5d getestet. Black Die dsMKIII sprengt aber auch meinen Einsatz und Finanzrahmen. Ich bleibe bei meiner Feingeist 5d, die auch noch excellent mit meinen Zooms harmoniert, und hoffe ja mal das BALD (Ich warte seit 7 Wochen auf die Lieferung) Meine 1DMKIII (Ohne s) kommt Black
Die Wahrheit ist ein Chor aus Wind Blacks Home (ok, im Aufbau, ich arbeite noch dran) Geändert von Blackmike (19.08.2007 um 15:15 Uhr) |
#9 | |||
Über KB-Format mache ich mir bei Sony weniger Gedanken da mir die Kamera schlicht zu teuer sein wird. Außerdem macht der KB-Sensor bis jetzt eh wenig Sinn........
#10 | |
Was ich persönlich gar nicht mal so schlecht finde. Denn das ein oder andere Schmuckstück taucht dann auf dem Gebrauchtmarkt auf, weil es an den Pixelmonstern den Zweck nicht erfüllt...;-) |
