Startseite » Forenübersicht » Kamera und Technik » Objektive » E-Mount Objektive (ILCE, ILME, NEX) » Tamron 17-70mm F/2.8 Di III-A VC RXD (Model B070)
Alt 03.12.2020, 11:51   #1
jsffm
Jetzt announced
https://www.tamron.eu/de/magazin/blo...del-b070-1063/
Tamron announces world’s first 17-70mm F2.8, wide range 4.1x standard zoom lens with VC for APS-C mirrorless cameras
PRODUCT HIGHLIGHTS
1. World’s first high-speed standard zoom lens for APS-C cameras with the focal length range of 17-70mm 4.1x zoom ratio
The Model B070 has a focal length range of 17-70mm, equivalent to 25.5-105mm on full-frame cameras. It is the first F2.8 high-speed zoom lens in the world for APS-C mirrorless cameras to achieve a 4.1x zoom ratio.
2. Outstanding optical performance
The optical construction of the new 17-70mm F2.8 features 16 elements in 12 groups. Two GM (Glass Molded Aspherical) lens elements and one hybrid aspherical lens element are precisely arranged to maintain high-resolution performance from edge to edge.
3. Upgraded VC effective in combination with Sony APS-C mirrorless cameras, leveraging AI for video shooting
The 17-70mm F2.8 features Tamron's proprietary VC mechanism. Additional sophisticated algorithms optimized for this model and a dedicated, independently operating MPU all combine to superbly compensate for vibration. This feature is available when the lens is used with cameras with or without in-body image stabilization. When shooting video, by leveraging AI technology, image stabilization performance improves compared to conventional models.
4. Close focusing−MOD is just 0.19m (7.5 in) at wide-angle end
The 17-70mm F2.8 zoom focuses close, down to 0.19m (7.5 in) MOD (Minimum Object Distance). This is far superior to the performance achieved by conventional high-speed zoom lenses for APS-C cameras. In addition, the 0.39m (15.4 in) MOD at the 70mm telephoto end ensures good close-range shooting performance allowing photographers to enjoy compelling close-up shots.
5. A highly portable compact design
The 17-70mm F2.8 zoom measures a scant 119.3mm (4.7 in) in length and 74.6mm in maximum diameter and weighs only 525g (18.5 oz). This is remarkable for a lens with built-in VC image stabilization. When used with Sony's APS-C mirrorless cameras, this zoom is nicely balanced and provides a comfortable user experience.
6. The RXD (Rapid eXtra-silent stepping Drive) stepping motor unit is exceptionally quiet and perfect for video use
7. Moisture-Resistant Construction and Fluorine Coating provide extra protection
8. Compatible with many camera-specific features and functions, including Fast Hybrid AF and Eye AF
Grüße aus Frankfurt,
Jürgen
Flickr APS-C lebt!
jsffm ist offline   Mit Zitat antworten
Alt 03.12.2020, 11:58   #2
jsffm
Tamron kündigt das weltweit erste1 17-70mm F2.8 Standard-Zoom-Objektiv mit VC-Bildstabilisator für spiegellose APS-C-Systemkameras an
Köln, 3. Dezember 2020 – Der japanische Objektivhersteller Tamron, führend in der Herstellung von hochwertigen optischen Produkten, kündigt die Markteinführung des 17-70mm F/2.8 Di III-A2 VC RXD (Modell B070) an. Das lichtstarke 4,1-fach-Standard-Zoom-Objektiv für spiegellose Sony E-Mount-Systemkameras mit APS-C-Sensor wird voraussichtlich ab dem 14. Januar 2021 verfügbar sein; der Termin kann sich jedoch aufgrund der andauernden Maßnahmen zur Eindämmung der Corona-Pandemie noch ändern
Produktbezeichnung
17-70mm F/2.8 Di III-A VC RXD (Modell B070)
Markteinführung
14. Januar 2021
Das neue 17-70mm F/2.8 von Tamron ist das weltweit erste1 lichtstarke 4,1-fach-Standard-Zoom-Objektiv für spiegellose Systemkameras mit APS-C-Sensor. Es bietet einen universellen Brennweitenbereich von 17 mm bis 70 mm (25,5 - 105 mm KB-Äquivalent) mit einer konstanten Lichtstärke von F/2.8 sowie eine hohe Abbildungsqualität. Es verfügt über das von Tamron entwickelte VC-Bildstabilisierungssystem zur Vermeidung von Verwacklungsunschärfe beim Fotografieren und sorgt mittels künstlicher Intelligenz (KI) für ruhige Bilder bei Filmaufnahmen.
Das Objektiv ist außergewöhnlich kompakt und leicht sowie gegen Spritzwasser geschützt. Die Frontlinse ist mit einer wasserabweisenden Fluorvergütung versehen. Wie die anderen Modelle der Tamron E-Serie verfügt das 17-70mm F2.8 über ein Filtergewinde von 67 mm, sodass ein Polarisations- oder Graufilter auf alle Modelle passt. Das Objektiv ist zudem kompatibel mit den fortschrittlichen Kamerafunktionen von Sony, wie Fast Hybrid AF und AF mit Augenerkennung, was es zur idealen Wahl in vielen alltäglichen Aufnahmesituationen macht. Die hohe Lichtstärke ermöglicht dabei kreative Schärfe-Unschärfe-Effekte, die üblicherweise nur professionelle Zoom-Objektive bieten.
PRODUCT-HIGHLIGHTS
1. Weltweit erstes1 lichtstarkes 4,1-fach-Standard-Zoom-Objektiv mit Brennweite 17-70 mm für APS-C-Kameras
Der 17-70-mm-Zoom des neuen Objektivs entspricht, umgerechnet aufs Kleinbildformat, einem Brennweitenbereich vom 25,5-mm-Weitwinkel bis zum 105-mm-Tele. Es ist das weltweit erste1 4,1-fach-Zoom-Objektiv für spiegellose APS-C-Systemkameras mit einer konstanten Lichtstärke von F2.8.
2. Exzellente Bildqualität
Der optische Aufbau des 17-70mm F2.8 umfasst 16 Elemente in 12 Gruppen, darunter zwei GM-Linsen (Glass Molded Aspherical) und eine Hybrid-Asphäre. Die Anordnung dieser optischen Spezialkomponenten gewährleistet eine über die gesamte Bildfläche hohe Auflösungsleistung.
3. Fortschrittliche VC-Bildstabilisierung in Verbindung mit Sony APS-C-Kameras, inklusive eines intelligenten Algorithmus für Videoaufnahmen
Das neue Standard-Zoom-Objektiv ist mit Tamrons bewährter VC-Bildstabilisierung ausgestattet. Sie verwendet einen eigenen Prozessor, um Kamerabewegungen effektiv auszugleichen und wurde um einen neu entwickelten fortschrittlichen Algorithmus ergänzt. Je nach Kamerafunktion arbeitet der VC-Bildstabilisator dabei entweder eigenständig oder in Verbindung mit der kamerainternen Stabilisierung. Bei Filmaufnahmen sorgt künstliche Intelligenz (KI) für eine äußerst effektive Videostabilisierung, die konventionellen Technologien überlegen ist.
4. Kürzeste Einstellentfernung nur 19 cm im Weitwinkel
Die kürzeste Einstellentfernung des 17-70mm F2.8 beträgt nur 19 cm. Mit dem neuen Zoom-Objektiv kann das Motiv somit aus geringerem Abstand fotografiert werden als mit herkömm-lichen lichtstarken Zoom-Objektiven für APS-C-Kameras. Bei 70-mm-Tele-Brennweite sind mit einem Mindestabstand von 39 cm beeindruckende Nahaufnahmen möglich.
5. Kompaktes und leichtes Design
Das 17-70mm F2.8 wiegt nur 525 g und ist mit einer Länge von gerade einmal 119,3 mm sowie einem Durchmesser von 74,6 mm für ein Zoom-Objektiv mit integrierter Bildstabilisierung außergewöhnlich handlich. In Verbindung mit einer spiegellosen Sony APS-C-Kamera bildet es eine gut ausbalancierte Einheit mit hohem Bedienkomfort.
6. Besonders leiser Autofokus mit RXD (Rapid eXtra-silent)-Technologie, ideal für Videoaufnahmen ohne störende Fokussiergeräusche
7. Spritzwassergeschützte Konstruktion und Fluorvergütung für zusätzlichen Schutz beim Fotografieren unter widrigen Wetterbedingungen
8. Kompatibel mit fortschrittlichen Kamerafunktionen wie zum Beispiel Fast Hybrid AF und Augenerkennungs-AF
Jürgen
Flickr APS-C lebt!
Alt 03.12.2020, 17:14   #3
kayf
Bin auf Testberichte speziell im Vergleich zum Sony 16-55 2.8 gespannt.
Aus den reinen technischen Daten ergibt sich für mich folgendes.
Vorteil Tamron 70 statt 55mm, Bildstabilisator
Nachteil Tamron 17 statt 16mm
kayf ist offline   Mit Zitat antworten
Alt 03.12.2020, 17:23   #4
jsffm
Ich hoffe auf einen günstigeren Preis.
Jürgen
Flickr APS-C lebt!
Alt 03.12.2020, 17:58   #5
ben71
Der Preis liegt bei 1099€ (UVP). Den Straßenpreis schätze bei 800-900€.
ben71
ben71 ist offline   Mit Zitat antworten
Alt 03.12.2020, 18:06   #6
jrunge
Gut geschätzt. Vorbestellung bei Foto Koch momentan 849,-€.
Gruß Jürgen
Alt 03.12.2020, 18:19   #7
ben71
Wow, das ging ja schnell. Danke für die Info
Dann bin ich mal auf Testberichte gespannt.
ben71
Alt 03.12.2020, 18:00   #8
DeauWilly
a 6500
+1
DeauWilly ist offline   Mit Zitat antworten
Alt 03.12.2020, 18:25   #9
Ja, 16 wäre schöner. Aber an der Dynax 7D bin ich auch jahrelang mit dem Tamron 17-50/2.8 ausgekommen. Wenn man das als Maßstab nimmt, hat man den Vorteil von 20mm mehr am langen Ende und keine Nachteile.
Alt 03.12.2020, 20:51   #10
kayf
Zitat von usch Beitrag anzeigen
Ja, 16 wäre schöner. .....man das als Maßstab nimmt, hat man den Vorteil von 20mm mehr am langen Ende und keine Nachteile.
Deshalb auch der vor lachen weinende Smiley.
Sehr attraktives Objektiv zum Sony 16-55. War dann doch gut, dass es das zum Shoppingwahnsinn letzte Woche nicht zum „MussManZuschlagenPreis“ gab
Alle Zeitangaben in WEZ +2. Es ist jetzt 20:17 Uhr.
