Startseite » Forenübersicht » Kreativbereich » Nach der Aufnahme » EBV mit GIMP - 3 Scripte
Alt 24.06.2006, 23:48   #1
FlorianLausB
Hallo Forum,
ich hab hier 3 Scripte für GIMP (laufen mit 2.2 und 2.3) welche euch vielleicht was nutzen könnten:
3DRI: dynamic range increase aus 3 Bildern einer Belichtungsreihe
5DRI: dynamic range increase aus 5 Bildern einer Belichtungsreihe
enlight: gezielte Aufhellung dunkler Bildbereiche
3DRI.scm:
Code:
(define (script-fu-3dri darkimg mediumimg lightimg adjust)
  ; load files
  (set! dri (car (gimp-file-load 1 darkimg darkimg)))
  (set! medium (car (gimp-file-load 1 mediumimg mediumimg)))
  (set! light (car (gimp-file-load 1 lightimg lightimg)))
  (gimp-image-undo-disable dri)
  (gimp-drawable-set-name (car (gimp-image-get-active-layer dri)) "dark")
  (gimp-image-add-layer dri (car (gimp-layer-new-from-drawable (car (gimp-image-get-active-layer medium)) dri)) 0)
  (gimp-drawable-set-name (car (gimp-image-get-active-layer dri)) "medium")
  (gimp-image-delete medium)
  (set! drawable (car (gimp-image-get-active-layer dri)))
  (gimp-layer-add-alpha drawable)
  (gimp-layer-add-mask drawable (car (gimp-layer-create-mask drawable 5)))
  (gimp-invert (car (gimp-layer-get-mask drawable)))
  (gimp-levels (car (gimp-layer-get-mask drawable)) 0 0 127 0.4 0 255)
  (if (> adjust 0)
   (begin
    (plug-in-gauss-iir2 1 dri (car (gimp-layer-get-mask drawable)) adjust adjust)
  (gimp-image-add-layer dri (car (gimp-layer-new-from-drawable (car (gimp-image-get-active-layer light)) dri)) 0)
  (gimp-drawable-set-name (car (gimp-image-get-active-layer dri)) "light")
  (gimp-image-delete light)
  (if (> adjust 0)
   (begin
  (gimp-image-undo-enable dri)
  ; show image
  (gimp-display-new dri)
(script-fu-register "script-fu-3dri"
              "<Toolbox>/Xtns/Script-Fu/3DRI"
              "3DRI"
              "Florian Lindner"
              "Florian Lindner"
              "2006"
              "RGB*"
	SF-FILENAME		_"dark" ""
	SF-FILENAME		_"medium" ""
	SF-FILENAME		_"light" ""
	SF-ADJUSTMENT	_"adjust"  '(50 0 1000 5 10 0 1)
5DRI.scm:
Code:
(define (script-fu-5dri file1 file2 file3 file4 file5 adjust)
  ; load files
  (set! dri (car (gimp-file-load 1 file1 file1)))
  (set! img2 (car (gimp-file-load 1 file2 file2)))
  (set! img3 (car (gimp-file-load 1 file3 file3)))
  (set! img4 (car (gimp-file-load 1 file4 file4)))
  (set! img5 (car (gimp-file-load 1 file5 file5)))
  (gimp-image-add-layer dri (car (gimp-layer-new-from-drawable (car (gimp-image-get-active-layer img2)) dri)) 0)
  (gimp-drawable-set-name (car (gimp-image-get-active-layer dri)) "medium-dark")
  (gimp-image-delete img2)
  (if (> adjust 0)
   (begin
  (gimp-image-add-layer dri (car (gimp-layer-new-from-drawable (car (gimp-image-get-active-layer img3)) dri)) 0)
  (gimp-image-delete img3)
  (if (> adjust 0)
   (begin
  (gimp-image-add-layer dri (car (gimp-layer-new-from-drawable (car (gimp-image-get-active-layer img4)) dri)) 0)
  (gimp-drawable-set-name (car (gimp-image-get-active-layer dri)) "medium-light")
  (gimp-image-delete img4)
  (if (> adjust 0)
   (begin
  (gimp-image-add-layer dri (car (gimp-layer-new-from-drawable (car (gimp-image-get-active-layer img5)) dri)) 0)
  (gimp-image-delete img5)
  (if (> adjust 0)
   (begin
  ; show image
(script-fu-register "script-fu-5dri"
              "<Toolbox>/Xtns/Script-Fu/5DRI"
              "5DRI"
              "Florian Lindner"
              "Florian Lindner"
              "2006"
              "RGB*"
	SF-FILENAME		_"dark-medium" ""
	SF-FILENAME		_"light-medium" ""
enlight.scm:
Code:
(define (script-fu-enlightenment img
                       drawable
                       gauss-radius)
  ; Create new layers
  (set! enlightenment-layer (car (gimp-layer-copy drawable 0)))
  (set! farbton-layer (car (gimp-layer-copy drawable 0)))
  (set! saettigung-layer (car (gimp-layer-copy drawable 0)))
  ; Give them names
  (gimp-drawable-set-name enlightenment-layer "Enlightenment")
  (gimp-drawable-set-name farbton-layer "Color")
  (gimp-drawable-set-name saettigung-layer "Hue")
  ; Add the new layers to the image
  (gimp-image-add-layer img enlightenment-layer 0)
  (gimp-image-add-layer img farbton-layer 0)
  (gimp-image-add-layer img saettigung-layer 0)
  ; set layer mode
  (gimp-layer-set-mode enlightenment-layer 5)
  (gimp-layer-set-mode farbton-layer 13)
  (gimp-layer-set-mode saettigung-layer 12)
  ; desaturate "entsaettigen" layer
  (gimp-desaturate enlightenment-layer)
  ; invert layer
  (gimp-invert enlightenment-layer)
  ; create layer mask
  (gimp-layer-create-mask enlightenment-layer 5)
  ; Call a plugin to blur the image
  (plug-in-gauss-rle 1 img enlightenment-layer gauss-radius 1 1)
  ; set opacity
  (gimp-layer-set-opacity enlightenment-layer 80)
  ; Flush the display
  (gimp-displays-flush)
(script-fu-register "script-fu-enlightenment"
              "<Image>/Script-Fu/Enlight"
              "enlightenment"
              "Florian Lindner"
              "Florian Lindner"
              "2006"
              "RGB*, GRAY*"
              SF-IMAGE "Image" 0
              SF-DRAWABLE "Layer to blur" 0
              SF-VALUE "Gauss strength" "15")
Sorry, wenig bis keine Kommentare ...
Immer her mit Kritik und Verbesserungen, ich bin blutiger LISP und Script-fu Anfänger.
meine Galerie
FlorianLausB ist offline   Mit Zitat antworten
Alt 25.06.2006, 12:29   #2
springm
Ich dachte schon ich bin der einzige Gimpel unter all den Photoshoppern hier.
Ich werd mir die Skripte mal zu Gemüte führen - meine letzten DRI-Versuche sind allerdings schon lange her. Was ich ab und zu noch mache sind DRI's aus einem RAW-File. Für RAW nehm' ich ufraw, das bietet meines Erachtens eine gute Oberfläche für dcraw. Bin ja gespannt, wie Sony das MRW-Format unterstützen wird.
Gruß - Markus
(Beinahe) Täglich neue Bilder: spring2life
springm ist offline   Mit Zitat antworten
Alt 25.06.2006, 15:48   #3
Hansevogel
@Florian
Habe mir soeben enlight zu meinem Gimp gepackt und ein wenig getestet.
Da kann ich nur sagen:
Sehr nützlich!
Gruß: Hansevogel
Alt 25.06.2006, 15:55   #4
FlorianLausB
Danke für die Blumen, das Know-How hinter dem Script kommt übrigens von dieser Seite. Da gibt's noch mehr brauchbare Gimp-Tipps
meine Galerie
Alle Zeitangaben in WEZ +2. Es ist jetzt 05:44 Uhr.
