Startseite » Forenübersicht » Kamera und Technik » Sony A-Mount Kameras » Gibt es hier echte Maenner? Backfocusproblem do it yourself)
Alt 06.01.2006, 17:43   #1
AGD
Nach ausgiebigen Tests bin ich draufgekommen, dass meine Kamera bei 85mm 1.4 einen leichten Backfocus zeigt. Nach recherche im www habe ich herasugefunden, dass man angeblich selbe Hand anlegen kann. Auswirkungen auf Garantie etc sind klar. Wer hat hier Erfahrung?
Zitat: Users debating this issue in another forum started looking at how the camera was assembled, offering theories on what was going wrong. One user figured out by looking at the CCD with the mirror locked up that 3 screws at the bottom of the camera controlled CCD alignment.
A Russian 7D owner with a backfocus problem (with his 50mm f/1.4) decided to experiment to see if he could fix his camera without the need to send it in for service.
He removed the rubber from bottom of the camera, put on a 50/1.4 lens (which he reported was absolutly unusable before due to the Backfocus problem), took a 1.5 mm hex driver, tripod and adjusted it. He said it took a total of about 15 minutes.
He said all he had to do was turn all 3 screws a quarter of a turn clockwise and it fixed it.
He also posted before and after photos showing how the problem was fixed (backfocus in photos before, no backfocus after). This 7D owner reported that his other lenses worked perfect. He said the has the Sigma 18-125/3.5-5.6, Minolta 28-85/3.5-4.5, Minolta 70-210/4, and Sigma 28-70/2.8.
This is not unusual (50mm f/1.4 with backfocus on this model, with other lenses working fine).
I would not attempt to fix a backfocus problem yourself (unless you don't have any other option). I was simply pointing out that I don't think it's a very big issue (a trip back to KM should solve it, *if* you get a camera with the problem). They would have the equipment and expertise to properly calibrate the camera (versus you trying to do it via trial and error).
Backfocus issues are not always the camera either. A lens can be out of calibration. It's a good idea to send both lenses and camera into a manufacturer (KM, Canon, etc.) if you have a backfocus or frontfocus issue. Users of 3rd party lenses sometimes send their lenses to the respective manufacturers for calibration, if it appears that the lens (versus camera) is at fault. KM would probably not try to calibrate a camera to a 3rd party lens (speculation on my part).
AGD ist offline   Mit Zitat antworten
Alt 06.01.2006, 18:42   #2
Sunny
Erleuchter
Ich glaube dass von unseren Usern noch keiner den Eingriff gemacht hat,
es ist sicherer die Cam nach Bremen zu senden
Alt 06.01.2006, 18:48   #3
AGD
Wo in Mexiko liegt denn genau Bremen?
Gruss
AGD
Alt 06.01.2006, 18:59   #4
Dimagier_Horst
Hallo AGD,
die Geschichte des Russen geistert schon lange in der Ewigkeit des Netzes. Es gibt auch die Variante mit einer Nikon und einem Russen. Und dann noch eine bebilderte. Es ist so wie das Gerücht um eine neue Blitzgerätegeneration von Minolta. Dabei gibt es Minolta gar nicht mehr .
Make Labskaus great again!
Glenroses Kentucky Stinger
Alt 06.01.2006, 19:06   #5
AGD
Also ich werde das heute mal mit dem Spieglein begutachten und dann berichten. Oder kannst Du tatsaechlich ausschliessen dass das funktioniert?
Dank und Gruss
AGD
Alt 06.01.2006, 19:28   #6
Sunny
Erleuchter
Ich könnte mir vorstellen dass es ohne Justierhilfen nicht funktioniert
Alt 06.01.2006, 19:54   #7
AGD
Ich glaube schon. Justiervorrichtungen gibt es ja im Internet zum runterladen, so auch hier: Backfocustestchart. Da kann man Backfocus messen und quantifizieren. Der Einfluss einer Schraubendrehung ist so leicht nachvollziehbar.
Kids, please don't try this at home!
AGD
Alt 06.01.2006, 19:58   #8
Sunny
Erleuchter
Hallo AGD,
warum schickst Du die Cam nicht zu Deinem zuständigen Service.
Stell Dir mal vor, Du schaffst das mit dem Fehlfokus und 3 Monate später hast Du einen Elektronikschaden,
sorry, dann ist die Garantie weg.
Alt 06.01.2006, 20:18   #9
AGD
Das werde ich vielleicht auch machen. Ich habe allerdings das Problem, dass ich in Mexiko keinen guten Service bekomme, und auf dem Postweg bei der Ruecksendung die Kamera im Zoll stecken bleibt.
Gruss
AGD
Alt 06.01.2006, 20:22   #10
Sunny
Erleuchter
Hallo AGD,
ich weiss ja nicht wie es in Mexico ist, aber ich würde die Ausfuhr und Einfuhr als Garantiereparatur deklarieren / anmelden.
Alle Zeitangaben in WEZ +2. Es ist jetzt 03:37 Uhr.
