Startseite » Forenübersicht » Kamera und Technik » Sony A-Mount Kameras » Is someone using Dynax 7D with ring flash R-1200?
Alt 09.12.2005, 15:40   #1
drcaste
If someone is using Dynax 7D with ring flash R-1200 I would like to ask him:
1) if he has problems with TTL: 1 out of 3-5 pictures of the same subject at the same position with the same manual settings, is underexposed
2) if the auxiliary lights (not the flash lights) are switching on with the gentle pressure of the "click" button of the camera as it used to be with the older version of the same ring flash or if they only switch on with the push of the button at the back of the flash controller
These two problems happen to me with the R-1200 and the controller MFC 1000 in both "preflash ttl mode" and in "flash adi mode".
If I use the built in flash no TTL problem at all.
Thanks for your help.
drcaste ist offline   Mit Zitat antworten
Alt 12.12.2005, 01:22   #2
U.Schaffmeister
Dear drcaste
i'm using the R-1200 MFC-1000:
1. No problems with underexposure. Not in TTL and not in manual mode.
Perhaps your photos are taken too fast for the flash reload.
2. The auxiliary lights can only switch on by the mfc-1000.
U.Schaffmeister ist offline   Mit Zitat antworten
Alle Zeitangaben in WEZ +2. Es ist jetzt 16:13 Uhr.
